Candy FP827X single oven.
  • #53979
    aqualectric
    Original fault was the fan element staying on when the oven was off. Swift tap with a screwdriver handle on the relay and all was well. The cabinet cooling fan motor was noisy and stalling so I changed that.
    Now the oven switches on but the cooling fan will not run. The wires are fine and they trace back to the control card PCB. I have tried everything apart from a new PCB. The fan motor was energised as the oven was switched on and there is no actuation stat for the fan either. Now I’ve fitted a new motor there is no power at the motor. 😕 Also, Connect show the PCB as obsolete……. :rolls:
    Anyone have a wiring diagram on PDF? Anyone had this problem before?
    Weird fault……. 🙁
    Any help appreciated!!
    Thanks,
    Steve.
    #317920
    aqualectric
    Re: Candy FP827X single oven.
    Anyone??
    Steve.
    #317921
    Serial number, two versions. 😕
    Assuming the first version…
    49002899 is the PCB, behind the control panel. It’s not obsolete, the first version’s production was only between 2001 and 2003. It shows up on CDSL as OOS but available, MP it’s POA.
    From the parts list (haven’t looked at wiring or service info yet) there’s really only the board and the temp. probe to go wrong.
    HTH
