Hi all can anybody advise me on this fridge problem before i return to fix it. its a candy fridge freezer half and half model 39011598 0307 1129c
first fault is the top hinge but i am able to cure that by reversing the door from left to right as old screw holes are woren. but when powering up the fridge it runs for a split second then dies. the customer said she previousley had the thermostat changed but is it a stat or a pcb controlling it ?
thank you bob both me and the customer were unaware of how this fridge operates 😳 i shall get back to her to replace the hinges then explain that she now needs to give the inside a good clean out 😆 thanks again
