I have a candy fridge freezer CM26/10PGB
The black pan which sits on top of the condenser has been ruined … by the heat of the condenser. Plastic has gone brittle and now the pan is mostly a hole. Design fault! 😯
For now I have put thick layers of kitchen foil over the huge hole. Personally I think this will do, but hubby is not sure.
Does this pan ever get FULL of water?
I’ve looked around for a replacement but cannot find one elsewhere.
Do you mean the tray on top of the compressor (black motor unit round the back)? If so, the replacement tray is p/no 97590921. spares@ukwhitegoods.co.uk will be able to get one for you. It’ll be a special order part, so a little patience will be required.
No, it should never get full of water. A little condensate will run into it and be evaporated off.
