Candy Fridge Freezer
  • #47400
    subs
    CP2913F/9. This fridge freezer is not getting cold enough in the fridge, about 12 degrees and not freezing properly in freezer. It seems to be cutting out too soon so im thinking fridge sensor. Now, this model is different to the Candy/Hoover ones im familliar with that normally over freeze and have the foamed in sensor that can be replaced. Although the fridge sensor seems to be foamed into the back of the fridge, when i looked up the part on connect it shows the sensor with complete lead and pc connection plug.
    My questions are, is the sensor foamed in in the same place as the other type that i have the instructions for?
    Is the sensor a common problem on this fridge?
    Subs
    #293340
    subs
    Re: Candy Fridge Freezer
    Somebody must have replaced the sensor on one of these before surely!
    Subs
