Candy Fridge Freezer CPCA 270 FFK Fridge Frozen Up
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Candy Fridge Freezer CPCA 270 FFK Fridge Frozen Up
  • #30047
    jccandy
    My Fridge is continually frozen up even though control is set to 0.
    No light showing on the control knob
    Liquid in bottles frozen
    Recently moved from one room to another
    Candy will fix for £100.
    Can anyone confirm what the problem is and if there’s an easy solution.
    the freezer appears to be ok
    thanks
    Jonathan
    #225659
    Re: Candy Fridge Freezer CPCA 270 FFK Fridge Frozen Up
    As with all combi fridge freezers, you start with a total defrost, then go again and see what happens.
    Sounds like a PCB failure which is probably enough reason to pay the ransom money. 😉
    jccandy
    Thanks for the advice, defrosting fingers crossed
    J
    #225662
    jccandy
    Have defrosted no joy though.
    It’s immediately cooling again even though the dials on 0.
    Also no light on the dial control regardless of the setting.
    Do you think this indicates the PCB fault referred to?
    Thanks again
