Candy Fridge Freezer CPCA 291FFK
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Candy Fridge Freezer CPCA 291FFK
  • #23053
    niall50
    The fridge in my 2 year old ‘frost free’ appliance has started to freeze its contents.
    Crystal ice forms on the inside rear of the fridge which has been de-frosted manually but refreezes once it is restarted.
    The freezer operates normally, however the compressor appears to be running continually.
    The fan is operating but the thermostat control appears to have no effect and the lights on the control panel do not illuminate.
    The fridge interior light (new bulb fitted) does not illuminate either.
    Can anyone provide a diagnosis please ?
    Thank you.
    #196878
    clivejameson
    Re: Candy Fridge Freezer CPCA 291FFK
    Did the old lamp rattle and look black when you took it out?
    #196879
    niall50
    Yes
    #196880
    Simon46
    Usually the electronic control module. Will fail in run all the time mode so you keep your freezer contents. Unplug power if you are going to have a lokk yourself.
    Regards
    Simon
    #196881
    clivejameson
    Yep, the module’s gone west 😕
    You could try Shop@ for a price of the module, straightforward to replace and would sort it.
    #196882
    niall50
    Thank you very much for the prompt responses and sound advice.
    I will obtain and fit a replacement this week and let you know.
    Cheers.
    #196883
    niall50
    PCB module replaced and appears to have solved problem however the appliance has been on for 3 days and the compressor has run continually during that time. Is this normal ? Could there be another related fault ?
    #196884
    niall50 wrote:Topic dated 3/12/06 refers – PCB module replaced and appears to have solved problem however the appliance has been on for 4 days and the compressor has run continually during that time. Is this normal ? Could there be another related fault ?
    Thank you.
    Duplicate thread deleted.
    Possibly short of gas? System work is pros only I’m afraid.
