Called to this mahine due to fridge fault, found failed P.C.B. New module is a different type, (typical). Tested after installing and found that the compressor was’nt kicking in as it should. After enquiring around, found there should have been an instruction sheet enclosed with the board. the new module has two links that are either removed or left in place according to particular models. Without the sheet I can’t tell what link to remove. Hope someone can help !!
