Re: Candy fridge freezer leaked brown gunk
scoobz wrote:So was this cooling fluid? Is it easy to fix? Could I do the repair myself?
Missed this.
No, not cooling fluid as there isn’t any.
Easy to fix depends on what the problem actually is. The two top culprits I could think of would be either spillage, which is the most likely or an insulation failure and the water is leaking through the insulation. The only other thing I can think of is condensation but that would likely hark back to an insulation issue.
Without knowing where the water is coming from, which you’ll have to track back, it’s difficult to do much bar have a guess at it.
