Candy Fridge Freezer problems
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Candy Fridge Freezer problems
  • #15664
    spikydiner
    My Candy Fridge Freezer (numbers on nameplate are CPC 240FFK, CF24) is freezing everything in the fridge compartment. Its also making constant loud whirring noises. I recently moved house so the fridge freezer was moved around and tilted quite a lot in transit.
    Altering the thermostat seems to have no effect whatsoever on the temperature, so i’m wondering if the thermostat might be broken. If so, how easy is it to replace a thermostat?
    #164413
    BobHope
    Re: Candy Fridge Freezer problems
    Hi Spikydiner
    your fridge freezer does not have a thermostat fitted its controled by an electronic pcb.
    if you turn the temprature control to the 0 position does your fridge stop working or keep running.
    Bob.
    #164414
    spikydiner
    Hi Bob,
    It keeps running! Even at 0 everything is still frozen.
    #164415
    BobHope
    Hi spikydiner
    the pcb control module has failed.
    time for the engineer to call, click on the repair toolbox on the lefthand side for an engineer close to you.
    Bob.
    #164416
    spikydiner
    Hi Bob,
    Thanks for the info. My partner has spotted the module for sale and is keen to have a go at fitting it himself. Can you give us any tips on how to do this?
    #164417
    gussay
    I have exactly the same problem, in that the fridge keeps running all the time and freezing my food, even though the control is on it’s lowest setting… 1
    Although I can turn mine off as it clicks just before it gets to zero, and stays of for a short time. But as the control springs back to 1, this is no use.
    Spikydiner, did you fit a new one and if so, how did you get on?
    #164418
    Dave_Conway
    I can get this module if required, an email to spares@ukwhitegoods.co.uk please for further info 😀
    #164419
    spikydiner
    Hi gussay,
    haven’t fitted a new module yet as we have a lot of food to eat up in the freezer before switching it off!
    Should fit it next week so will let you know how it goes.
    Spikydiner.
