hi i ordered a seal to fit this model the original one was just felt, the seal that has come is not felt and has a sticky backing, has it been changed or have they sent the wrong seal the part no on the new one is 49116619 thanks john
hi i finally fitted this seal i cleaned the old adhesive off first , about a week later the customer rang to say it had partly come off again , after i fitted it originally the drum was very stiff to rotate should the seal be lubricated with ptfe ? thanks john
If the seal was that tight I would have contacted whoever you bought it from as they have modified it due to steam escaping and causing problems with the modules
