Candy frost free help please
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy frost free help please
  • #18230
    allan
    Don`t do much in the way of refridgeration now, but had to call on a regular customer with a candy frost free fridge freezer, there was a large amount of ice in the freezer, it was solid and looked like it had flowed out near the bottom engulfing the lower baskets so as not to be able to get them out! I have asked her to defrost it and will go back today. Any ideas or pointers would be appreciated
    Thanks Allan
    #178230
    Dave_Conway
    Re: Candy frost free help please
    Defrost heater or thermostat failure I would think, possibly the PCB if it has one (no model number to check ;))
    #178231
    allan
    Sorry mod is CPC 290 FFK
    #178232
    Dave_Conway
    It does have a PCB then. Possibles as above in that case, defrost heater, thermal fuse etc.
    #178233
    allan
    Thanks, have been back and finished defrosting the thick ice whiched filled the gully and drain hole, turned it off and back on went into defrost mode, defrost heater works fine although not very powerful. could it be design fault?
    Allan
    #178234
    Dave_Conway
    Possibly a one off, if it happens again though 😕
    Is there no seperate drain heater ?
    #178235
    allan
    No drain heater, but I wrapped a length of wire around the part of the heater above the drain and positioned it into the drain hole, hopefully this may help keep it clear?
    Thanks for your replys and help
    Allan
    #178236
    agro
    Yep a lot of models struggle with this .I also run a piece of wire down the hole seems to work .But i do wonder why the main manf dont do it although i have seen a unit with the element going down the hole.
    #178237
    robbo1973
    hi had this fault a lot i move the defrost sensor from inside the evap and tie wrap it too the evap entry after the capillary where it is the fattest never been back to one 😉 .the sensor is generally right next to the heater bringing off defrost too early.
