Candy G0482/1-80 N-3100246709020475
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy G0482/1-80 N-3100246709020475
  • #67208
    Rograbbit
    Happy new year folks.
    90 minute time to end and stain vanish flashing simultaneously, three flashes at 6-7 second intervals.
    looked at known codes and it may be a drain time out but not sure if relates to this model. Any help appreciated. This one is intermittent, so could be blockage I suppose if the fault code is a drain time out.
    Thanks.
    #366659
    BobHope
    Re: Candy G0482/1-80 N-3100246709020475
    check the wash heater, common known problem, you will need an insulation meter to check it, put it on quick wash wait untill the heater is on for 5 mins and then test it.
    Bob.
    #366660
    Rograbbit
    Thanks Bob. I did megger the heater on my last visit, but as you say it could be when it gets warm. it’s been ok for a few weeks but she doesn’t use it too often.
    Thank you. 😀
    #366661
    DDSDDS
    just done same today halfway through 3 flashes funnily enough though i got an intermittant 16 flash did not got earth leak on heater till it was warm….also found that i had an earth leakage on the front displap board i could actually put my test meter on and get an audible beep on continuity test cleaned excess carbon dust off and fitted new heater going like a good one now
    #366662
    BobHope
    the common faults for earth leakage on these is E3 and E16.
    Bob.
