Candy gcc580 nbs-80 leds flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy gcc580 nbs-80 leds flashing
  • #98518
    slyp98
    Hi all, more headaches this one is less than a year old , all the leds flash and beep at 1hz, any info available thanks K , ser. 3110065715430042
    #472679
    cant see any useful info
    at under a year then its under warranty isnt it ?
    cant see any child lock
    does it flash as soon as you turn on ?
    slyp98
    No after about 30 seconds , prob sensor issue
    #472681
    i would check heater stats first
    slyp98
    Installed in a shop so no warranty,
    #472683
    slyp98 wrote:Installed in a shop so no warranty,
    unless they took it home
    unless it looks like its been battered
    Hollytree_Technical
    I may be wrong but something in the back of my mind says to check the heater relay to see if it is stuck on.
    Jem
    #472685
    kaibart
    They ended production the end of 2017 so I would check heater falling that will be pcb
    #472686
    slyp98
    Its not the most appealing
    I will price pcb for them see what comes up
