Candy GCC590NB stuck on pause
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Candy GCC590NB stuck on pause
  • #98594
    ASB1960
    On trying any program the pause light flashes. This is the only light lit in any way.
    Pressing start there is a long beep, no apparent attempt to start and the pause light restarts flashing.
    If I press and hold the start button for a few second then all the lights flash 3 times.
    If this is E3 (and I am unsure) then this appears to be a water full condition (the light is not lit). The resevoir is empty not full and appears well seated.
    Any suggestions as to where the problem may lie.
    Thanks.
    #472984
    kaibart
    The 1st thing to check would be connections on the door lock and the door lock itself
