Our Candy GCC591NB tumble dryer is nearly 3 years old and out of warranty.
It has developed an issue where the drum will not start to turn on its own.
The motor sounds as though its trying to turn but it does not seem to start it moving.
If you take out the washing and give the drum a quarter turn manually with your hand it then after closing the door and putting washing back in seems to run fine for that cycle fine.
But once it has been stopped and left for a while it has the same issue again.
Someone mentioned it could be a capacitor that is needed but other than that I have no idea.
Any advice would be great.
Many hanks for your time.
Andrew
