Candy Go 1482-80 PCB fail
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy Go 1482-80 PCB fail
  • #61820
    Peepo
    Hi, The main PCB has failed in our Candy Go 1482-80. Multiple tracks have burnt out on the underside.
    Can anybody point me in the right direction to get a replacement please?
    Also, we still have the receipt and the machine apparently has a 5 year parts warranty. How does that work? I am guessing that you need to have a Candy approved engineer to fix the machine and that labour would cost a fortune? :rolls:
    Thanks in advance for any help.
    Rob.
    #347716
    gandh1
    Re: Candy Go 1482-80 PCB fail
    candy labour approx £100
    would be worth going with though, because its very common for candy/hoover motors to take out the main pcb. both parts combined = write off of the appliance.
    you could alternatively post a hi-res pic of the pcb & burnout, and we can advise what may have caused that???
    #347717
    Peepo
    I’ll post a hires scan of the PCB this evening after work.
    Thanks.
    #347718
    Peepo
    Scan as promised.
    #347719
    Specialist01269
    Hi: If you follow the wires from the 3 burnt pins you should find what’s caused the burning on the other end. Are any of the components on the other side looking burnt?
