Candy go c58f condenser dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Candy go c58f condenser dryer
  • #86691
    7seaton
    I have a candy goc58f that’s not getting hot and after about 20mins all the lights flash together at approx 1-2sec intervals, I was suspecting a thermal cut out or heating element.
    Am I on the right track if not can anyone off any advice on what it could be, any advice on how to test the sun specked component will all be appreciated
    K
    #432767
    cvel
    Re: Candy go c58f condenser dryer
    I had one of these candy machines a while back that had the same fault. I changed both thermistor on the heater element and worked perfectly after that. You will need a multi meter to check these and is very easily done and ruled out. Good luck.
    #432768
    7seaton
    Hi, I have changed the heat element on the back with the 2 sensors on top of it. The machine now gets hot but still cuts out after 10mins with all the panel lights flashing.
    Is the any type of relay or thermal cut out switch?
    I have also checked the condenser unit for blockages
