Re: Candy GO DF 800
really simple
plug out
pull machine out
remove back
remove belt , motor plug, earth wire and 2 10mm bolts holding motor
motor slides off pegs and can be got out
brushes are in black holders at rear of motor
you could try a quick test
plug out, pull machine out and tilt it up 45 degrees to get underneath. (some machines have a plastic cover underneath which you move out of the way) You will see the brush holders at the back of the motor. tap each one firmly with the plastic handle of a screwdriver. put machine back down and try it
if it runs you have just proved its the brushes. If it does not it still could be so you have to take the motor out to check
