Candy GO146
  • #53620
    allan73
    I would be gratefull if anyone can help with the following fault, customer complains of candy GO146 aborting programme and 1st option LED flashing 7 times. My fault code book seems to suggest motor fault yet cutomer is able to finish on a spin programme also sometimes completes a rapid wash without problems. would be pleased for any help (new to site).
    #316664
    loopey
    Re: Candy GO146
    ERROR 7(MDL) – Jammed Motor’s Rotor and/or Wiring.
    ERROR 7(INVENSYS) – Defective Door Safety Lock Device (blocked closed) and/or Wiring.
    ERROR 8 Defctive Tachometric Dynamo (opened or shorted) and/or Wiring.
    #316665
    allan73
    Re: Candy GO146
    Thanks Loopey, I’ll check motor & associated wireing if all seems ok is this likely to be a board fault ?
    #316666
    loopey
    Re: Candy GO146
    mega the heater had a simular one today new heater sorted it 🙂
    #316667
    allan73
    Re: Candy GO146
    Only just got to this today, problem seems intermitent & customer not in too much rush.Insulation tested heater fine, motor fine checked carbons,tacho (sole motor), windings continuity fine. Also tested wires from board to motor even valves i have checked. Puzzled on this one have to admit, the belt however seems slightly slack could this be slipping with full load in and being read as a fault or is main board more likely ?
    #316668
    allan73
    Re: Candy GO146
    Can anyone help with this please?
    #316669
    Re: Candy GO146
    allan73 wrote:Can anyone help with this please?
    Give me your email address and I’ll send you some info. 🙂
    #316670
    allan73
    Re: Candy GO146
    I would like to add that i think ive solved this one now.
    Called back to m/c at weekend customer complaining of popping noise now.
    Sure enough motor clicking when i turned the drum, previously i had examined the motor (not carefully enough ?) and insulation tested it. Motor now ordered, thanks for the help everyone.. 😀
