Candy GO1482 stain and 90 degrees flashin
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy GO1482 stain and 90 degrees flashin
  • #75039
    andysam
    went to above appliance and cleaned the sump hose had crap in it the machine still flashes. the stain and 90 degrees lights are flashing during the cycle. any help appreciated.
    #393677
    Rograbbit
    Re: Candy GO1482 stain and 90 degrees flashin
    If you are getting an F3 fault, which is poor drain, this error also throws up when the heater is going down to earth on Hoover/ Candy. Put on a quick wash, let the heater come on for a while, disconnect leads and check insulation resistance.
    #393678
    andysam
    found out the above are ok its when it comes to the rinse cycle its not doing it and then flashes any quick way to put on a diagnostics test?
    #393679
    Rograbbit
    Sorry I’m not sure someone else might have to help on that.
