candy GO282 goes straight to fill
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries candy GO282 goes straight to fill
  • #70821
    slyp98
    hi guys , have this m/c select program all lights flash once then off and m/c starts to fill and fill and fill , tried pess switch no joy looked at board lots of the tracks are furry and dry joints too , anyone got this prob b4 cheers
    #379068
    Re: candy GO282 goes straight to fill
    first call on all these type of faults is earth problems nice to rule it out early as a lot of electronic controlled parts are neutral switched
    next i would change the triac on the board that controls the valve. it does not take a lot of leakage to fire a valve
    after that its probably the board
    slyp98
    cheers dave , no earth fault so i’m just gonna bite it and order a board cheers
    #379070
    its prob only the triac
    find out which one by buzzing wires back and solder another one in. do it all the time and if you pinch it off a scrap board it cost nothing to find out
