Re: Candy GOC218 condenser drier stops during cycle.
aqualectric wrote:Thanks Martin – but would the timer motor still run? It stops when you open the door and starts when the door is closed and start button pressed……..weird!
Weird indeed Steve especially so because, and according to the wiring diagram, the door switch cuts off the neutral return to the entire machine. So for the timer motor to continue to run could mean and earthed return was at large somewhere?
