Wondering if anyone could provide a wiring diagram for the above T/D?
Called by customer to rectify a no heat fault, who has already replaced several parts himself. (heater unit, front sensor, and pcb)
Heat is evident very intermittently, and I suspect a wiring fault unless there is another sensor somewhere. (have checked related wiring continuity thus far, but was running late for next job.)
Hi jonty I attach a wiring diagram for you more than likely the new pcb needs programming with men loader Hoover has, this condenser has 2 ntcs 1 on the front duct and 1 under the drum in the rear left i would suggest fitting all the old parts back on and starting from scratch as the old pcb is probably fine, its always a head ache when customers try to fix themselves. Kai
