Candy GOF462-80
  • #65014
    peeler40
    Machine does not pump out .Emptied the water from the machine
    And set it to spin .but the machine thinks its still in wash mode so fills up and starts washing .Can you reset the machine
    so it will just do a spin ?
    #358796
    Re: Candy GOF462-80
    When the fault happens does the 1st option button LED start flashing? If the heater has the slightest leak to earth these symptoms will prevail. In most cases that LED will flash 3 times to give you a clue. 😉
    Are you getting a supply to the pump at any point by the way?
    Also, whip out the coreboard and check for blown triacs and the like. Well worth a gander. Resetting m/c just requires you to press and hold the start button for 5 secs then turn the selector to ‘off’.
    #358797
    helo_75
    Re: Candy GOF462-80
    erm, are you sure its not just the selector on the pcb?
    quite a common fault on those
    spin the control knob round 6 or 7 times really fast and try agai
    #358798
    peeler40
    Re: Candy GOF462-80
    Thanks for the replies the machine still will not reset .Will
    follow your advice and take another look .Thanks again .
