Candy GOFS 272 flashing light & stopped cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy GOFS 272 flashing light & stopped cycle
  • #67506
    Ad86
    I have recently moved house and my 10month old Candy washing machine has some kind of fault.
    Basically on say 2 out of 5 washes it will get about 15mins into its cycle and then stop. With the top indicator light flashing twice, then few secs delay, twice, delay. And so on…
    Any ideas what the fault could be thats causing it to happen?
    We do now live in a town house (street is a row of houses), and so suffer from rather low mains water pressure. So im thinking thats got something to do with it? It never happened whilst in our old house. Maybe just coincidence, but maybe not?
    Any ideas?
    #367647
    Re: Candy GOFS 272 flashing light & stopped cycle
    It is an error code.
    You are correct I think, low water pressure and the fill times out, detailed here as error 2.
    Not a lot you can do if you can’t get the water pressure up. 😕
    HTH
    Ad86
    I thought it would be down to that. And yeah theres nothing that can be done about it. We are at the end of the street, and a shared water mains pipe.
    Hence our cold water taps supply water at the same sort of rate/pressure as a gravity fed hot water tap,lol.
