Candy GOV58F lights flash
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy GOV58F lights flash
  • #59317
    stamm
    After starting the dryer approx 10 secs all the lights on the control panel flash all at once. The lights can be reset by holding in the start/ pause button for approx 5 secs.
    Have checked the vent hose not kinked & that the filter is clean. The manual is of no help at all.
    Any ideas as to what may be wrong to cause the alarm.
    Thanks in advance
    #337678
    helo_75
    if you try the dryer 3 or four times, does it eventually work?
    how old is it?
    is it in a garage?
    #337679
    stamm
    Re: Candy GOV58F lights flash
    Yes it starts off & keeps going after 3 or 4 goes but the next time it may run 1st time.
    No its in a utility room not in a garage.
    The machine is just over a year old.
    #337680
    helo_75
    there is a fix for that
    its ambient temperature lockout
    it needs reprogramming
    #337681
    stamm
    Hi Helo
    What do you mean ambient temp lockout? Why is it intermittent & how do you reprogramme?
    #337682
    helo_75
    of your room temperature drops below 10 degrees, the thermistor gets out of its normal tolerance level and the pcb cannot read it
    ony a hoover (or comet) engineer can reprogramme it, you need a memory writer to do it!
    #337683
    stamm
    Many thanks for the reply helo_75 its much appreciated. I think we will live with it for now as we can imagine the cost of callout etc.
    Stamm
