Good afternoon,
Wondering if anyone could shed some light on a problem with the above washer/dryer?
Essentially, having selected a wash cycle the machine draws a small amount of water, then washes briefly, prior to aborting the cycle.
When it plays up, the stainblaster and 90′ led’s flash.
I tried other cycles, including rinse, spin, and drain only with the same outcome.
I cleaned out the pump filter, which had some unusual black charcoal type pieces in the pump housing.
The appliance is not drawing much water on wash, or rinse cycles, so I wonder if this is related, or a possible board fault?
Kind regards,
jonty
