Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Candy Grand Evo faults
- This topic has 12 replies, 6 voices, and was last updated 11 years, 3 months ago by
mobi.
December 22, 2014 at 3:03 pm #83493
mobi
ParticipantHi all, I’m new here so I hope I can get some help.
I have a candy grand evo which developed fault e3. poss blocked drain, removed the drain pipe and found it full of soap slime, undid pipe both ends and pulled through a piece of cloth on a wire, checked pump turned ok, filter clear, pipe from drum clear.
Now it may do a complete wash cycle or it may stop with 4 minutes to go with error code e03 or e16. and the door stays locked. I know the heater is ok as it heats up the water, If I switch it off for a minute then select drain cycle it may drain out properly.
So I reckon the pump is working ok, could it be the water level sensor having a “wobbly” now and again.??December 22, 2014 at 3:11 pm #422882kwatt
KeymasterRe: Candy Grand Evo faults
We’d need the full model number please, that’s just a series.
December 22, 2014 at 4:21 pm #422883mobi
ParticipantRe: Candy Grand Evo faults
Sorry about that, the model number is evo1682D/1-80
December 22, 2014 at 5:04 pm #422884Jackal
Hoover / candy group machines when throwing up BOTH E03 & E16 are 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time reporting an earth leak on the heater.
The heater needs to be meggered for even the slightest trace of an earth leak. If that meters ok, you have a defective Coreboard
Jackal
December 22, 2014 at 5:09 pm #422885Andy jones
Yep almost certainly the heater
December 22, 2014 at 5:45 pm #422886mobi
Thanks all, I shall set to and check the heater. Cheers.
December 23, 2014 at 10:40 am #422887mobi
Ran another test run,this is the result.
Put on 30 min wash, running ok up to 8 min; left, then stopped. E03 error
Switched it off and drained 700ml out, door still locked. switched on to spin, error E16 up, door still locked. Pulled out plug for 2 minutes, door unlocked.
plug in, switch on , put on spin 7. starts ok, turning slowly, pump working, down to 6, spin starts slowly, pump working,5 same 4 same, then jumps down to 1, stops. no 1600 spin, end. drained out further 250ml, that’s it.
As this did not need heater at all I am confused.?December 23, 2014 at 11:48 am #422888Andy jones
It’s an earth fault on heater that causes problem as already said. Doesn’t matter if you select a problem that’s not using it. Heater needs meggering to be sure
January 24, 2015 at 7:09 pm #422889mobi
Hi all, sorry for delay in answering, fitted a new heater as suggested and all is well again, I can again have some clean clothes.!! Thanks to all who suggested the answer, very helpful.
September 5, 2015 at 10:00 pm #422890Andonis68
Hello , I have a similar problem. I stripped the pump down, cleaned it out, blew down the waste pipe, there was no blockage.
How do you meter an earth leak on the heater please before I order a new one? I am capable and know ho to use a mulitimeter.
TonyCandy Grand Evo, EVO9143D/1-80
September 6, 2015 at 6:44 am #422891Martin
You measure the resistance between each terminal and earth. A 9v multimeter is not capable of registering a fault. You need a 500v Insulation meter. An essential tool we use in the trade in detecting earth leakage faults and checking the electrical safety of any electrical appliance we repair.
September 6, 2015 at 8:45 am #422892Andonis68
thanks martin, looks like i need to buy a heater first , then a pump.
I put the machine on a cold short wash yesterday. it got down to 3 minutes before the end and conked out with e03. i may have 2 problems at the same time here.October 17, 2015 at 6:53 pm #422893Andonis68
thnaks guys, i tired to use a MEGGER but in the end i changed the heating elemnt and it fixed it. thnaks again Tony
