Candy Grand Vita
  • #102312
    mfearnon
    I have power getting to the board but nothing is happing, is there anything else I can check?
    Model GVC D101WB 80
    #488294
    no light or anything
    if yes board power supply has failed most likely
    mfearnon
    Yeah no lights etc, just power going in
    #488296
    well i would say its a board fault
    you either need to fix the board which means soldering electronic components or you replace it
    dave
    #488297
    andyjawa
    And if you go down the replacement board route as far as I`m aware that main power board is model specific i.e. when ordered it will be pre programmed for your specific model and serial number. Yes I know, it`s a pain in the arse.
