Candy Grando E08 Error – GO DF800
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy Grando E08 Error – GO DF800
Viewing 15 posts - 16 through 30 (of 30 total)
  • #413839
    mystic.bertie
    Re: Candy Grando E08 Error – GO DF800
    Martin wrote:
    mystic.bertie wrote:
    0.5 ? ohms, i was going by what i saw on you tube, test the resistance
    No the resistance is incorrect. Does it generate voltage when you rotate the armature? I guess not. 🙁
    Don’t you just love those YouTube video’s. :rolls:
    Sometimes youtube videos are useful, maybe not in this instance 😀
    I did not check for voltage, what should i set my meter to and can i test it without refitting the motor?
    thanks for your help, we will get there, i hope 😉
    #413840
    Set your meter to DC volts and spin the armature. I swear I mentioned that earlier. 🙁
    #413841
    mystic.bertie
    Hi Martin, sorry for the delay, here is pics and a video, are my setting correct and is the reading im getting correct?
    cheers
    video on the tube on you
    https://www.youtube.com/watch?v=0u0l9s6 … e=youtu.be
    #413842
    The tacho is duff judging by that. Looks like a Chinese motor too. 🙁
    #413843
    mystic.bertie
    Ok thats great, many thanks for confirming this. Ill get one on order and report back once its fitted and i hope its good news. Yeah made in china motor, are these far less reliable?
    #413844
    mystic.bertie wrote:Yeah made in china motor, are these far less reliable?
    Verry less rerriable…… Much lubbish! 😉
    #413845
    mystic.bertie
    lol, cheers Mr Miyagi
    #413846
    mystic.bertie
    Hi, im afraid after fitting the new tacho the machine still does not work, same problem, fills and drains but does not rotate and then throws up the E08 error.
    #413847
    I expect the motor triac has probably blown then on the main circuit board….?
    #413848
    mystic.bertie
    Hi Martin, can this be tested in any way?
    #413849
    Yes just look at the component side of the PCB.
    #413850
    mystic.bertie
    I had a look with a torch but nothing obvious, should i remove it for a closer look, if so how do i remove the pcb does the knob on the front just pull off?
    #413851
    mystic.bertie
    Can anyone help me any further on this?
    PLEAZzzzzzzzzzzzzzzzzzeeeeeeeeeeeeeeeeeeeee
    #413852
    Did you inspect the PCB more closely for component damage?
    #413853
    mystic.bertie
    Martin wrote:Did you inspect the PCB more closely for component damage?
    Hi, i need to get it off for a proper look, from what i can see there is no damge but im limited as to what i can see, how does it come off?
