Candy Grando E08 Error – GO DF800
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy Grando E08 Error – GO DF800
Viewing 15 posts - 1 through 15 (of 30 total)
  • #80713
    mystic.bertie
    I recently bought a second hand Candy Grando GO DF800. It worked fine when i got it home and tested it. I moved house days later. I dropped it on a bottom corner during the move so the bottom feet got bent up and in a bit, i tested the machine and it done a handful of washes just fine. Then days later the drum wont turn and i get this E08 error. The machine fills and drains but wont turn.
    SO after seeing a vidoe on testing a hoover motor with the e08 error, i proceeded to check the brushes which had about an inch of life in them. I used my cheap multi tester (dial & needle type) to check the ohms on the 2 wires coming from the tacho, i get zero and zero when i turn the motor. I have the motor off at the moment.
    So can someone tells me if this sounds like the tacho needs fixed or any other suggestions,
    Many thanks guys 😉 😉
    #413825
    Re: Candy Grando E08 Error – GO DF800
    Tacho fault or complete motor
    Bryan
    #413826
    mystic.bertie
    r600a wrote:Hi
    Bryan
    Cheers mate, should i replace the tacho first, can i test the motor in any way?
    I cant find the tacho spare part do i need to go to Candy for this?
    #413827
    The tacho is available if you give me the product and serial number which starts normally 31************** 16 digits long and also which motor is on the machine ( sole ) ect.
    We can supply the part
    Bryan service@ffrservices.co.uk
    #413828
    mystic.bertie
    GODF 800/L-80
    3100455312145234
    I cant see any branding on the motor apart from a label saying Applied Motor Technologies, made in china
    #413829
    mystic.bertie
    SO is testing the tacho a bit of a hit and miss as i read a post where the guy got bad readings from the tacho, replaced the tacho and the brushes and still had the E08 error.
    #413830
    mystic.bertie wrote:I dropped it on a bottom corner during the move so the bottom feet got bent up and in a bit, i tested the machine and it done a handful of washes just fine. Then days later the drum wont turn and i get this E08 error.
    I think the clue might be in that statement. Secondhand machine, transported from pillar to post, been dropped and so on. I’m guessing throughout that time the drum wasn’t secured and therefore the wiring to the motor will have born the brunt.
    Check the wiring harness and motor plug very closely.
    #413831
    mystic.bertie
    Hi.
    The terminal block was still attached to the bracket on the motor and there is lots of slack in the wiring so it does not look as though the cables got harmed.
    How reliable is testing the tacho with a multimeter?
    #413832
    mystic.bertie wrote:How reliable is testing the tacho with a multimeter?
    Very. Spinning the armature should generate current noticeable on a multimeter.
    #413833
    mystic.bertie
    maybe i should get a decent multimeter and test it, i have one similar to this below, just a cheap screwfix one, so im not sure how reliable it is, i get a zero reading when turning the motor shaft.
    #413834
    mystic.bertie
    i can borrow a better multimeter from work, ill test the tacho tomorrow night and report back. cheers
    #413835
    mystic.bertie
    Ok i just tested the tacho and it is only going as high as 0.5. Does this mean i definitely need to change the tacho.
    #413836
    mystic.bertie wrote:Ok i just tested the tacho and it is only going as high as 0.5.
    0.05 what? A magnetic tacho generator is axactly that, a generator, of voltage. It should register a rise in voltage and if it does, no matter how minimal, it proves it works.
    #413837
    mystic.bertie
    0.5 ? ohms, i was going by what i saw on you tube, test the resistance, is this correct? SO does it look like my tacho ok?
    #413838
    mystic.bertie wrote:0.5 ? ohms, i was going by what i saw on you tube, test the resistance
    No the resistance is incorrect. Does it generate voltage when you rotate the armature? I guess not. 🙁
    Don’t you just love those YouTube video’s. :rolls:
