Candy Grando no go.
  • #66504
    GO 1482-80
    31001954-0809-2268.
    Just had a quick butchers at the error codes thread but this one doesn’t appear to be flashing an error code, is there a diagnostic mode?
    Select any programme and press start, door locks but machine does nothing else.
    The door lock light flashes continuously until switched off. Holding the Start/Pause button in gets all three lower lights flashing together with the time countdown light, again it just continues flashing without a pause until switched off.
    Machine is upstairs in a cupboard. :rolls: I just about managed to pull it out far enough to tip it back and have a look underneath, motor/brushes look fine. Needs a couple of doors removing to get full access.
    Any suggestions welcome, including take it to the top of the stairs and let gravity take its course. 😀
    bazza500
    Re: Candy Grando no go.
    Give me an email addy Jim, and I’ll fire off a service manual.
    #364368
    heater element could be worth a look at.
    #364369
    eastlmark wrote:heater element could be worth a look at.
    If I could have got the darned thing out I would have. 😉 😀
    iadom wrote:GO 1482-80
    31001954-0809-2268.
    could have done a reach around and tug the heater wires off then.
    #364371
    It was all I could do to actually get a look at the comm area. 😛
    #364372
    Went back to this earlier today.
    Heater, motor etc all megger perfectly.
    Try as I might I could not get the Auto test routine to run.
    Held button 1, turn knob to position 2, release button 1 as soon as all lights come on, press start button after 2 secs and before 5 secs.
    This is where it all goes wrong, I should now have the three option lights flashing alternately with the residual time and spin speed light.
    In fact the three option lights and the residual time light are flashing together and alternating with the single spin speed light, it will not progress past this into the test routine. 😥
