Candy heat pump T/D
Home Forums Trade Technical & Spare Parts Forums Candy heat pump T/D
  • #98855
    AASWALES
    Hi I have been asked my a neighbour to look at a heat pump dryer , they said they were no longer getting water into the container . Normally I wouldn’t do heat pumps but as its a neighbour and seemed like a blockage or pump I thought ok ill have a go , well what a nightmare, completely dismantled to find no fault with the pump impeller or blockages , ran the machine for a good hour and the clothes were luke warm . Is there a way to test if the the compressor has lost gas ? Compressor body feels hot as do some of the pipes tested the temp at 50c on top pipe at compressor, the cold pipe was not ice cold as I would have expected its was cool at around 13c ? Any advice would be really appreciated thanks alan
    #474036
    you cant check for gas problems without putting guages in the system and then you need refrigeration training and info on gas, loading etc
    if the clothes are warm i would say its working and the system is a heat pump that moves heat from evaporator to condensor.
    are clothes drying ?
    have you checked seals. ?
    if you can touch evaporator when its running it shoul be cold and wet through dropped condensation
    AASWALES
    Thanks for the reply , the clothes are warm but it takes a long time to get warm , the evaporator doest seems to be as cold as I would expect and bearly any condensation, I asked them to try a load in this afternoon and after 2 hours nothing in the water collector , seals and fans all working, its very clean inside with no fluff clogging anything, I think it is low on r134a as the low line doest even get cold enough to sweat ? High line is very hot cant hold it for more than a few seconds
    #474038
    this is the problem with these dryers, once the fridge system fails its game over
    how old is it ?
    AASWALES
    2 years old
    #474040
    well it may be covered by a parts warranty as long as he pays Candy’s labour
    as a long shot have you got the model and commercial code so i can look up to see if the list any known problems
    bryan-206
    If it gets warm but you get no water I’m afraid its got no gas. Dead in the water. Claim under the parts warranty.
