serial no-n3100259708170137.Problem :Starts and runs for about 15 secs then stops and stainwash and time remaining 90 minutes both lights flash 5 times ,pause then 5 flashes again and will do this wherever set.I know machine pumps out,fills,spins/drum goes round,and element is ok.Have replaced PCB today which is the correct one and is brand new and is programmed but is worse than the original as this one will not turn on the pump but still screws up the same way as original with the 5 flashes.Any ideas anyone please?
