hi, i’ve had a candy cpca270ffk for 2 years now not a problem. 2 days ago the light went out in the fridge bought a new one fitted it. didn’t work now all my food is frozen. freezer compartment fine, sounds fine, any ideas?
hi
could be faulty light switch or lamp holder.some fridges have a thermal protector in the lamp housing that will need checking if your candy has one.
if all above and the new lamp are ok then problem may be in pcb.
I’d recommend you ask an engineer to confirm fault.
