Candy oven dead, power only to timer
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Candy oven dead, power only to timer
  • #77841
    chris78
    Hi everybody,
    I hope someone can help. My Candy FPP6071X oven is dead, doesn’t heat up, the fan isn’t working and no lights on. Only the timer works. Set it to manual and it counts back and beeps at the end. Which part can be faulty?
    Many thanks
    #403587
    Re: Candy oven dead, power only to timer
    If the timer is being set to manual and flipping back to auto then it’s possible the timer is at fault but, I’d check that thoroughly before replacing it.
    Ensure that it’s not on some sort of program before you replace it basically.
    chris78
    Thanks for your reply. Sorry I wasn’t clear. The timer stays on manual. Just set a cooking time for testing and it counts back as usual. But the oven won’t start in manual nor in automatic mode.
    #403589
    Could be an overheat stat then, a terminal block or the function switch.
    At least, that’s what I’d be looking at first before going for the most expensive item to replace.
