Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Candy oven door seal
- This topic has 9 replies, 3 voices, and was last updated 12 years, 5 months ago by
spanner51.
October 19, 2013 at 6:12 pm #77697
spanner51
ParticipantHello
I have a Candy built in single oven and the model number is completely unreadable. It needs a new door seal. I tried a 4 sided universal one (from Connect) but it is too thick, and the door wont shut properly. I also tried a gen Candy one p/n09201356 but that is too thick as well.Dimensions are 450mm wide, 430 high
Can anyone suggest an alternative, or a thin universal one.
Graham
October 19, 2013 at 6:14 pm #403114admin
KeymasterRe: Candy oven door seal
Hi Graham
Model number will be on the outer cabinet of the oven as well if you pull it out..
How old and do you have a photo of it.
Bryan
October 19, 2013 at 6:19 pm #403115spanner51
ParticipantRe: Candy oven door seal
Hello Bryan
I have had it out but couldn’t see a model number. Its about 6 years old. I could get a photo and post it Mon.Thanks for your reply
Graham
October 21, 2013 at 5:10 pm #403116spanner51
This is the oven in question. I wasn’t there at 9.35pm, the clock is wrong.
Graham
October 21, 2013 at 5:31 pm #403117Martin
Is the product number (e.g 33??????) visible at all anywhere?
October 22, 2013 at 12:14 pm #403118admin
Hi Graham
If I am correct then this is a pyro oven that does not have a standard seal but a seal on the actual door.
The seal is in stock with GIAS and is available from myself PM me for costs ect.
Bryan
October 22, 2013 at 2:24 pm #403119spanner51
Hello Bryan
The old seal was on the cabinet, just like a usual one, with the hooks in the corners, only it was quit thin. Not sure I know the meaning of the term ‘Pyro Oven’. Maybe its a modification, and the one you found would fit.
This is the kind of job which is costing me far too much time, but hay ho
Thanks for your efforts
I have had the oven out. No stickers or numbers, apart from the one on the front edge which is totally unreadable
Graham
October 22, 2013 at 2:50 pm #403120admin
Hi Graham
I have been looking through The builds of approx. 2006 – 2009 for the type of control panel used and they are all showing this as the seal ?
Bryan
October 22, 2013 at 2:58 pm #403121spanner51
I would say that is it. The old one was completely perished on the bottom edge and hanging off, so It may not have been complete on all 4 sides. You said earlier it was available from yourself, so let mr know
GrahamOctober 23, 2013 at 7:53 am #403122spanner51
or the part number would be great
thanksGraham
