CAN ANYONE ADVISE HOW TO REMOVE THE ELEMENTFROMTHIS MODEL? THERE ARE NO SCREWS IN THE BACKPLATE OF THE OVEN AND ON SLIDING IT OUT AND REMOVING TOP & BACK PLATES I STILL CAN’T SEE THE ELEMENT. ANY ADVICE APPRECIATED THANKS
have the back panel removed- still cant see the element , lot of wires though do i have to disconnect these and remove a further panel, any other thoughts appreciated…..
You should now have a “sandwich” – the element is between the panels. Take pictures/make diagrams of all wiring before removing it as we can’t help you if you drop a stitch.
Remove the whole assembly, then you can access the screws to separate it.
