CANDY PCB CONFIGURATION
  • #33814
    dna
    Please cabn someone supply me with the confiruartion to a pcb for candy cnw156
    thank you
    #240166
    Re: CANDY PCB CONFIGURATION
    dna wrote:Please cabn someone supply me with the confiruartion to a pcb for candy cnw156
    First of all we need the 8 digit product number (3???????) to establish if the coreboard (module) you require is pre-programmed or not?
    If it is NOT then only Gias engineers can fit it as they carry a MEM Programming unit (Modules Eeprom Manager) designed to do just that! 😕
    The part no’s (of the Modules) as follows: –
    97923706 Coreboard Pre-programmed
    41011826 Coreboard Not programmed
    HTH?
    #240167
    dna
    Hi martin the numbers i have are
    3100060705275035
    CNW156T80
    The PCB that was fitted was the un configured one hence the problem we are having can you confirm the part number for the configured on.
    The fault agian is that it is continuly draining. machine mega up 252Mohms.
