Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Candy PVI 640 C induction hob
- This topic has 11 replies, 4 voices, and was last updated 10 years, 11 months ago by
alexinapot.
May 12, 2015 at 9:48 am #84943
alexinapot
ParticipantPosted this in Other Appliances by mistake but it probably belongs here:
Hob is about 6 years old and has been fine until now when it gives error code E1, which according to the manual is ‘Abnormal voltage in the power supply’. Seems odd as nothing has changed and if we had supply problems they would surely affect other appliances too.
If I contact Candy they will say that it’s not an appliance problem so will probably call in the electrician who did the kitchen. Just wondered if anyone else had had this problem and what was the cause.
Any advice welcome
JC
May 12, 2015 at 11:20 am #427227electrofix
ModeratorRe: Candy PVI 640 C induction hob
when does the unit fail?
when you switch the unit on at the wall or
when you put a pan on and start cooking ?
May 12, 2015 at 1:57 pm #427228alexinapot
ParticipantRe: Candy PVI 640 C induction hob
Fails immediately you power it up. Then keeps showing the fault code until you cut power again
May 12, 2015 at 2:29 pm #427229electrofix
sound like a board fault. you could measure the voltage to see if its low or high but apart from that cant think of anything else. as a quick test you could disconnect it and power it up from another source such as a socket. since it does not need to be in use to fail you will know quickly.
as a long shot check its earthed ok. cant seeing it making a difference but its longshot time
DaveMay 12, 2015 at 2:32 pm #427230alexinapot
If it was a board fault would it only affect one appliance?
May 12, 2015 at 2:40 pm #427231electrofix
yes or any appliances on that circuit if it was a circuit fault
you dont live on a strange electric supply do you like way out in the countryside or you own generator or anything like that ?
DaveMay 12, 2015 at 3:09 pm #427232alexinapot
No – just bog standard supply
May 12, 2015 at 4:34 pm #427233admin
KeymasterRe: Candy PVI 640 C induction hob
Do you have the product and serial number as there are 4 variants to the PVI640 ?
Bryan
May 12, 2015 at 4:42 pm #427234alexinapot
There is a Product Code of 33800476 if that means anything but I have no other numbers
May 13, 2015 at 2:29 pm #427235alexinapot
Update.
Electrician confirms supply is ok. Candy engineer coming next Tuesday. I told them the fault code when calling but I bet the engineer picks up on it.Meantime been looking at what’s available if we do have to replace. Bosch do one that simply plugs into a 13amp socket. This is rated at 2.9kW. They also have one that seems identical but is 4.6kW and would obviously not be 13 amp.
Ok – I realise that one is more powerful but what would this mean in practical terms? Presumably they both do the same job, both heat pans in the same way. Would one be quicker? If not why pay a higher purchase price and have the added complication of dedicated wiring? Don’t expect to have to replace but having seen this am just interested in the difference.
JC
May 13, 2015 at 3:16 pm #427236don
The PIA611B68 13A allows you to use two zones at max power. If you activate all of the zones 2.9kw is shared between all four. The attached explains it a little nicer 😉
DonMay 14, 2015 at 2:11 pm #427237alexinapot
Thank you, Don. Makes sense now.
