Candy single built in oven
  • #61876
    cornflakes
    model: FL102/1w uk
    other numbers 33700420 07350089
    had my local supplier get mea quote for replacement main oven thermostat
    says its £73.00 plus Vat retail
    this stat is similar to a range of stats as its only a
    push in at back of control switch,
    anyone have a more realisitic cost of replacement or offer an alternative one
    many thanks
    graham
    #347914
    Re: Candy single built in oven
    92128719 Connect have it at £48.50 + vat. with no pattern equivalent listed. Masterpart P.O.A. Looks like a perfectly simple two tag stat with 1/4″ flat shaft. You could get half a dozen or so cheap pattern stats for a lot less and choose the one that fits best. Or take the old one, including knob for temp range, in to your local supplier and see if he can find you a match from stock.
    Mike.
    #347915
    cornflakes
    thanks for that, was of the same opinion its only a basic temp range stat
