Candy SP100 Door
Home Forums Public Support Forums Spare Parts Help Candy SP100 Door
  • #6505
    I wonder if anyone can help, the door for my candy sp100 has broken. the white plastic clip that secures the door has snapped, as far as i can see i will need to replace the whole door as this is a moulded unit – does anyone know where i can obtain a new door (or lock assembly if a whole door is not needed)
    Thanks In Advance
    Mark
    #118025
    Re: Candy SP100 Door
    Mark,
    Is your machine a Candy SP100TR ‘Sprint’ ? If so the complete Door assembly is part number 91670645 (Around £50)
    …or can you be a little more specific(where this white plastic clip is?) as to exactly what has broken on the door as some individual parts are available for the above model 🙂
    There is a sticker inside the door that says it’s a sprint 100 (it doesn’t mention tr) on the front of the machine it says sprint 1000 (again no mention of tr)
    The clip that is broken is on the inside of the door – there is a big halo that appears to hold the glass in place against the front of the door (the screws go through the halo that has the broken clip. the clip is moulded to this piece and has a metal latch just above where the clip was. – it looks as if the door comes apart in two pieces front to back with the glass pined in the middle – i need the back piece
    thanks for your help
    hope this makes sense
    #118027
    Dave_Conway
    You really need the product code to identify these parts correctly.
    It will be on the rating plate, prbably inside the door opening somewhere, or on the back of the machine. It will begin with 3????????
