Machine has module checked, motor replaced, pressure switch replaced, and the Timer replaced, but still refuses to spin.
Machine will agitate with water in , pumps out ok, and goes into distribute as it is ramping up the machine shuts down.
Yes, with a full load in the drum the machine shuts down. Had the module checked by QER and stood next to technican, witnessed it spinning ok thats whats so unusual.
I remember years ago on at least two occasions when the servis quartz was ramping up to spin, the program just cleanly reset with no fault code indicated.It turned out on these occasions to be the RF suppressor at fault. It was not filtering the noise from the brushes and the board was influenced by this unwanted input!
