Candy Technical Bulletin
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Candy Technical Bulletin
  • #80575
    Grahamdust
    Does anyone have details of technical bulletin 2006/007/FR for the modification needed to fit the replacement circuit board to a Candy fridge freezer model: CBCA260UK. The old module had an 8 pin connector and the new one uses only 6 pins because I understand that the sensor which was previously external is now built in, but apparently the wiring configuration needs to be changed.
    Many thanks
    G D
    #413366
    Re: Candy Technical Bulletin
    Whats the Product number ?..Found it but you also need the new housing.
    Bryan
    #413367
    Grahamdust
    Hi Bryan
    The cabinet product number is 34916189. I am told that the new housing gives the necessary extra ventilation.
    Thanks Graham
