Candy thermostats
Home Forums Trade Technical & Spare Parts Forums Candy thermostats
  • #97288
    delta01
    Hi does anyone know the value / temp of the stat and toc on the heaters for these condenser dryers model no,CS-C8LF-80 thanks John
    #466790
    unless the stats are provided by a reconised supplier its not worth the risk of fitting stat that may or no be to spec
    also there are 2 heaters fitted to this model dependant on serial no, one of them has a non gen equivalent for about £20 so not worth the risk for that price
    what you have to think these days is if the tumble dryer fails and causes damage any work you do would come under the spotlight. If you have fitted correct part then they cant blame you
    delta01
    Thanks Dave
    #466792
    if you need to know the correct heater post the serial an i or another member will look it up for you
    have done it anyway
    delta01
    Thanks again Dave
