Candy tumble dryer
  • #65856
    mattpitman
    Why will my Candy tumble dryer only stay on when I keep the ‘on’ button depressed?
    #362132
    Re: Candy tumble dryer
    Well if you gave us a full model number we might have a better idea. 😉
    Possibly a relay fault.
    #362133
    mattpitman
    Sorry, it’s a Candy CIC60.
    #362134
    Most likely fault is the relay on that machine.
    RELAY
    #362135
    mattpitman
    Is this relay something that is easy to fit? I.e. for a numpty like me is it easy to access etc….without taking the thing to pieces?
    Your advice is very much appreciated.
    #362136
    Any numpty will do, just make sure you unplug the machine first, lift the lid and you’ll spot the relay just behind the control fascia.
    If you are the least bit apprehensive over the task then do please contact a local engineer for them to sort it for you. One such can be found by clicking HERE!!! 😀
