Candy tumble dryer ovehreats
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Candy tumble dryer ovehreats
  • #80073
    radiator
    Hello
    I have a problem with my tumble dryer Candy go dc 38g. It’s a condenser tumble dryer.
    The dryer is overheating. It stops after approximately one hour, there is no beep, the clothes are still a little wet, and they smell like they are burning. I have cleaned all the lint out, have measured the heater, and it shows just below 50 ohms resistance, have replaced the main thermostat (130°C), and I have also measured the two probes (sensors) and they both change the resistance equally when heat is applied. Don’t know what else to do. Any suggestions would be helpful.
    #411588
    Re: Candy tumble dryer ovehreats
    Have you changed the thermistor (NTC) at the front?
    #411589
    radiator
    The dryer has two thermistors. I have measured both of them, while applying heat (cooker plate), and the resistance have changed for both of them equally. Have I done this right?
    #411590
    radiator wrote:Have I done this right?
    Yes that’s fair enough evidence they are working OK. An error code is shown by both the Start and the Stop LED’s flashing together. I guess that is not happening? So it may be that the two thermistors resistances are not being detected by the circuit board or that the connections to it are at fault?
    Tough one to figure out on this old beast TBH. 🙁
    #411591
    radiator
    I have measured the NTC cables and they are OK. I have also looked at the circuit board. Nothing is burned or anything, but something looks funny. Have posted pictures bellow. I don’t know what LED’s are flashing, because the dryer is completely disassembled.
    #411592
    The only sure way to ensure that corrosion hasn’t caused continuity problems on that PCB is to reheat the solder lines.
    #411593
    radiator
    Could the capacitor for the motor be the problem? Or is that just for stating the motor? Because in the capacitor doesn’t have power to turn the barrel at certain speed, the clothes could burn, and the safety switch turns off the tumble dryer. What do you think?
    #411594
    If the motor doesn’t rotate because of a faulty start capacitor then the fan doesn’t rotate also. If the fan doesn’t rotate the heater overheats and the TOC immediately cuts off the heat. So, no I don’t believe the motor capacitor is connected with your current problem.
    Replace it by all means to put your mind at rest if you like. They often fail anyway and are a cheap as a portion of chips to buy. So you have little to lose. 😀
    #411595
    radiator
    I have replaced the PCB with a used one, and so far it works fine (tested two times). I have also noticed that the door seal is leaking, and maybe that is the cause for the failure (water got on the PCB and something short-circuited). Thank you for your help.
