Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Candy W/D bizarre no fill fault.
- This topic has 11 replies, 5 voices, and was last updated 17 years, 1 month ago by
simtoms.
February 19, 2009 at 4:33 pm #43601
simtoms
ParticipantCandy CMD146-80, about 13 mths old :rolls: door locks, drum turns but no fill and no power to solenoid valve. Heater within normal parameters. On rinse fills fine. Drains fine. Just no fill on any wash. Cold fill only. Any bright ideas? Thanks. Simon.
February 19, 2009 at 5:11 pm #277857Martin
ParticipantRe: Candy W/D bizarre no fill fault.
simtoms wrote:Any bright ideas?
Does the start LED and option button LED flash when this fault occurs? 😕
February 19, 2009 at 8:36 pm #277858simtoms
Thanks Martin. No, it seems to trundle on through as if everything was fine. I obviously havent watched a FULL cycle, but customer says it goes on through to the rinse cycle, which then fills as normal.
February 19, 2009 at 9:49 pm #277859smartin
had one the other day it had a voltage lockout (240 to both pins) from pcb have ordered board, but is worth checking the obvious as well 1st like brushes and heater down to earth
February 19, 2009 at 10:09 pm #277860leavemetogetonwithit
Pressure switch/ pressure system OK? (Thinking it might be intermittent).
Mike.February 19, 2009 at 10:20 pm #277861simtoms
Thanks Gents, dont think blocked pressure system cos its only 13 mths old and it seems to fill ok on rinse. Fault also seems to be consistent.
Will double check heater and brushes….February 21, 2009 at 11:56 am #277862Micky 32
ParticipantIt seems like the machine thinks there is water in it. The pressure switch would be the first thing i’d be checking.
February 26, 2009 at 1:04 pm #277863simtoms
Picking up my old thread here…
The customer NOW informs that it does start flashing eventually.
The active rinse light and the 90 min. light adjacent both flash 3 times and then pause. Candy model again, CMD146-80.
Does anyone have fault codes please? Thanks. Simon.February 26, 2009 at 1:15 pm #277864Martin
3 flashes = Drain time out.
I have the info you require Simon, you just need to give me your email address. 😉
February 27, 2009 at 8:51 am #277865simtoms
Hi Martin, I have sent you a private message with my email for the info you were kindly going to forward. Thanks, Simon.
February 27, 2009 at 9:06 am #277866Martin
I don’t seem to be receiving pm’s for some strange reason? You’re the second person that said a pm was sent….Not in my inbox mate sorry.:?
Best to just let me know here and I can sort it. 💡
February 27, 2009 at 5:13 pm #277867simtoms
Thanks Martin. Its “simtoms@gmail.com”
