The above washer has bown the control module in the center to the right of the heat sink, just wondering if anyone has had the same fault on this model as I don’t want to renew it to find there is a fault somewhere on the machine and it blows again, tried to follow the trcks but it’s to badly burnt
i had one where the wires going to the water valve were rubbing on the dryer, i sent the pcb to emw and got it repaired, the mormally tell you to check something if its an obvious fault.
