Candy Washer Dryer Double Quick 1500
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy Washer Dryer Double Quick 1500
  • #35737
    lizgo
    I have a 3 year old Candy Double Quick 1500 washer dryer. The washing machine is working fine it’s the tumble dryer thats not. It is make a really loud grinding noise. I have checked for bra wires etc :oops:. I went into local repair shop to ask his advice he says it is bearings and not to bother replacing as its too expensive. My dilemma is, is it worth replacing or do I buy a new machine. Thanks for any advice, Liz.
    #247839
    Re: Candy Washer Dryer Double Quick 1500
    I have moved your fridge question from the Spares forum to the refrigeration forum.
    Also now moved this post from Spares to the Washer forum.
    You will have a much better chance of a reply if you just stop for a second and make sure you have posted in the correct place, 8) 🙂
    Hope fully someone will be along soon who will be able to fully answer your questions.
    However if your machine is quiet on wash & spin then the main bearings are OK.
    If the noise only occurs during the drying cycle and not the spin then the dryer fan motor or fan could be faulty.
    Does it only make the noise on dry?
    lizgo
    Thanks for your reply, yes noise is only on the dry cycle.
    #247842
    Well worth getting it looked at, preferably not by ‘the man in the shop’ 😉
    Try the link at the bottom of this post if you need help.
